Deck Beam Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 08:28 PM   #1
Knucklez's Avatar
Rewards Points: 930
bugger.. when i built my front portch i used two 2x8's with a 1/2" PT spacer (cut so the water runs off it) and sandwitched the three items together. but what i found was that the tops of the boards were not perfectly flush.. so i had to shim in some 1/16" galvenized metal (some Simpson strong tie thing) so joist would sit on both beams.
so my backyard shed i decided to build beams differently.. just sandwitch them directly, no spacer, and use water proof membrane to protect the seam. but i find the same problem! i used my body weight to make sure the bottom was flush because i want the weight transfered to the posts evenly.. but now in SOME areas the beams are not flush on the top. what to do? shim again? hit it with a sander? don't worry about it?
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 08-03-2014, 10:07 PM   #2
Knucklez's Avatar
Rewards Points: 930
i learn later in life it matters not at all. all the weight from joists will be on the beam (at least half of the beam) and the nails sandwitching the beams together will transfer the stress to the other. no problems.
i also learned how to better match the beams so they are level while forming.
Old 08-03-2014, 11:31 PM   #3
Rewards Points: 222
when i was doing my deck, i found that some of the 2x8's were not the same thickness.
Fix'n it is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Building a deck with 4x10s on a ledger and beam KrisWithak Building & Construction 5 03-27-2011 10:37 AM
Steel beam for deck billybarty Building & Construction 2 08-18-2010 01:27 PM
Beam Construction kemp Building & Construction 4 09-14-2009 11:26 PM
