Deck Baluster Spacing Incorrect - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 08:21 AM   #1
Question
I recently built a deck and discovered that my baluster spacing is too large by 1/4". The spacing is 4 1/4" vs. 4" per code. I used 3/4" diameter aluminum balusters and I am looking for a way to increase the diameter. i.e. adding a plactic sleeve around the baluster.
Has anyone run into this issue before and are there recommendations on how to correct without redoing all of the balusters?
TM
tmcmahon is offline   Reply With Quote
Old 10-02-2012, 08:33 AM   #2
Rewards Points: 13,270
Post a picture.
A simple piece of 2 X 4 used as a gauge cut to 3-3/4 long would have made sure they were spaced correctly.
Old 10-02-2012, 05:32 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
did someone say something about it to you, if its only a 1/4" it will usually slide..
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (10-02-2012)
Old 10-02-2012, 05:57 PM   #4
Rewards Points: 502
Originally Posted by joecaption View Post
Post a picture.
He wanted ideas on what to do to correct it, not how to have set it out in the first place.
As the journeyman said, it's only a little over and while the Codes have to draw the line somewhere, its not as though its like 5".
If it has been flagged up, could he (temporarily) wire some chicken wire over it? Just wondering.
tony.g is offline   Reply With Quote
Old 10-02-2012, 06:02 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Second this!
Usually not a big deal.
Ground level deck or raised?
sublime2 is offline   Reply With Quote
Old 10-02-2012, 06:13 PM   #6
Rewards Points: 692
Squeeze them into an ellipse until each side gains 1/8".
Old 10-02-2012, 06:28 PM   #7
History....deck baluster spacing incorrect
Thank you for the quick feedback.
This is an elevated deck, about 4ft max at one point. I ended up with 4 1/4" because I measured the spacing on the deck I built back in 2003, which was 4 1/4". Ends up the code changed in 2005 from 6" to 4". No question that this was my mistake.
I am working with the building inspector to see if this could be grandfathered in based on the new deck being an addition / extension to the current deck. So far it doesn't look promising.
One idea I had was to take pieces of split plastic tubing and place it over each baluster to make up the 1/4". Something similar to split conduit covering.
I like the idea of squeezing them into an elipse, but I have about 400 balusters to correct.
Old 10-02-2012, 06:31 PM   #8
Rewards Points: 2,210
How hard would it be to just remove them, move them to 3&3/4 and add more?
Might be best and easiest in long run.
mae-ling is offline   Reply With Quote
Old 10-02-2012, 07:54 PM   #9
Difficult to replace
It would be difficult to replace them since each baluster is recessed into a pilot hole, top & bottom. All of the 2x4's would need to be disassemled, flipped, re-drilled and then reassembled.
Old 10-02-2012, 08:08 PM   #10
could tyou post some pics so we could give some ideas
Old 10-03-2012, 09:46 PM   #11
Deck Photo
I am proud of how the deck turned out, with the exception of the baluster spacing.
Old 10-04-2012, 05:30 AM   #12
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not Bad at all for a DIYer Project.
- Build Well -
Old 10-04-2012, 07:55 AM   #13
GBrackins's Avatar
Rewards Points: 2,108
huh? can you explain?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-04-2012, 08:18 AM   #14
Rewards Points: 3,130
I had to think about this for a bit too. The balusters are round, so flattening them would make them a bit wider. But the suggestion has to be a joke - I can't imagine it could be uniformly done, not to mention the number of balusters on that deck.
Old 10-04-2012, 09:05 AM   #15
GBrackins's Avatar
thanks md2, guess I hadn't had enough coffee this morning.
if this is a sticking point with the building official what is the possibility of installing a larger diameter baluster? if not .....
most jurisdictions have a board of appeals, a board where you can take individual issues to to seek a variance or exception to the code. if you cannot come to a meeting of the minds with the building official over 1/4" then I would suggest appealing to the board of appeals and explaining what happened and how compliance at this point would create a financial hardship.
In Massachusetts the local building official interprets and enforces the state's uniform buildingcode. If you believe they have either interpreted the code incorrect, are enforcing it unfairly, or you have a situation that does not comply with the code you can go before the BOA and present your case.
Gary
Tags
deck building
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Outside Baluster Spacing DangerMouse Building & Construction 65 05-18-2009 02:11 PM
Baluster Spacing chicago woodman Remodeling 4 12-08-2007 12:19 PM
