Deck Addition - Possible? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 12:50 PM   #1
Rewards Points: 308
deck addition - possible?
Hey all,
I'm considering a deck addition as shown in the attached illustration on the left side.
So per the illustration "question point" - the side of the original existing deck (far outside left joist) is a 2x10.
Could I attach deck hangers to the outside of that , and run new joists perpendicular and out to support a new section?
Alternately, I could actually add a third new leg (not shown, it would be in the lower right corner of my new section) - then run a header from it to the outside left edge of the top/left leg of my existing deck, bolted through.
denemante is offline   Reply With Quote
Old 10-09-2012, 02:59 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
you could just build it free standing, not attached to the other deck at all.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
mae-ling (10-09-2012)
Old 10-09-2012, 03:37 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
if you are looking to attach new joists 90 degrees to an existing outside joist I think you may find the existing joist will be not able to support the load. You would need to create a beam of sufficient size to support the new imposed load.
Read through this and it may aid you. It is the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
post back with any questions.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-10-2012, 12:06 PM   #4
if it was me, i would build it freestanding. If you are worried that i may move a little and see it separate while on the deck, build it freestanding and bolt the new joist to the current. if that makes sense
Kissfan4 is offline   Reply With Quote
The Following User Says Thank You to Kissfan4 For This Useful Post:
Two Knots (10-11-2012)
Old 10-10-2012, 02:09 PM   #5
Rewards Points: 308
This project started as a little platform to house my grill. So perhaps 2 feet out and 4 feet wide. Then it grew into what I've described.
If I just wanted a little 2x4 foot rectangle hung off one side of the deck, could I cantilever it out somehow, or would I really be talking about the same thing?
Old 10-10-2012, 02:53 PM   #6
GBrackins's Avatar
check out Figure 1A on page 3, and Table 2 on page 3 of the "Prescriptive Residential Wood Deck Construction Guide" that I provided a link to in post #3. You can figure out based upon this how much you can cantilever your deck.
Good luck!
Gary
Old 10-11-2012, 08:20 AM   #7
DIY-er
From your drawing, it looks like there is nothing to cantilever. If you were going to cantilever it, it would extend out in the other direction from where you want the deck addition. According to GBrackins link, it looks like the code says that the max. extension for a cantilever is 1/4 of the joist span. However, the building code in your area may say different. Where I live, the max. cantilever is 24 inches. Here is another link for cantilever info ... http://www.decks.com/deckbuilding/De...w_far_can_it_s
You show that you would add two new posts on your drawing. I would install a third post adjacent to the top of the stairs and use the existing one in the top left hand corner as the fourth - then you will have a box-like structure to build the deck extension. You could run your decking and joists in the same direction as the existing. Might want to check with an engineer or deck builder on this one.
KevinPh is offline   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
5/4 x 6 or 2 x 6 PT Decking, what would you choose? Quicksmoke Building & Construction 9 08-23-2011 08:17 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Leveling a deck denemante Building & Construction 10 08-24-2010 08:11 AM
