Deck - 45 Spindles - Advice Wanted (pics Inside) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-21-2007, 01:55 PM   #16
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
If each section is identical I would consider making insert panels. Then I could build the panels in a jig in the shop. Essentially build a frame with some 1/2"x 1" strips then attach the balusters to that. Your jig will show you exactly where each baluster will go. The frame will be easy to split so pre-drill your holes if you use screws. I would use 2 brads for each end untill I got everything where I wanted it and then add one screw to each end of each balluster. When finished you will not have any visible connections except for attaching the frame to the rails.
Even better would be to use something like Deckorators aluminum balusters. You could cut them as required. Then they could be set into holes at each intersection. It would certainly look cool. A cheaper alternative would be to make your own deckarators style balusters. I have thought copper pipe might look cool.
Brik is offline   Reply With Quote
Old 05-21-2007, 05:57 PM   #17
Home Improvement Guy
ron schenker's Avatar
Originally Posted by bujaly View Post
Hey Kevin.. Totally random question. How did you create that photo that you posted?
This thread is 2 years old, Kevin is probably long gone
ron schenker is offline   Reply With Quote
Old 05-21-2007, 06:27 PM   #18
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
bujaly,
I don't think you'll have much luck getting an answer to your question since this thread has been inactive for about 2 years.
FWIW - I thought the the post before yours mentions the name of the program that the person used to do their drawings....check it out.
- Build Well -
Old 05-21-2007, 06:54 PM   #19
Handyguy
Brik's Avatar
Crap - I hate when I don't realize an old thread was re-started. Duh.
Old 05-23-2007, 05:07 PM   #20
That is too effin funny!!
I didn't even look at the year. I just looked at the date and saw 5-11.. HAHA!!!
bujaly is offline   Reply With Quote
Old 06-06-2007, 11:22 AM   #21
Rewards Points: 530
Since this is not too old a post and I saw this, I have to ask a question. Is copper and the chemicals in pt lumber not a no-no?
Old 06-06-2007, 11:28 AM   #22
Handyguy
Brik's Avatar
I don't know but would be curious as well.
Deck ledger/carriage bolt question colaminecanary Building & Construction 9 07-31-2007 08:16 AM
Painted deck - advice needed! Sallie Painting 5 03-23-2007 12:03 AM
This is bad, right? (pics inside) dalesd Roofing/Siding 8 02-16-2006 09:33 PM
