Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 01:03 AM   #1
Deck
I am building a 12 x 16 deck between two houses. What I am reading if I understand it right on figuring joists and spans is if you use a 2 x 10 you can span 16.1 feet from ledger board to post on a footer for 40psf live load and 10psf dead load. Would it be the same if I were going from ledger board to ledger board or is that too much pull on the ledger boards.
tayna is offline   Reply With Quote
Old 07-02-2011, 07:43 AM   #2
Rewards Points: 5,336
If you're spanning 16 feet between 2 houses, I would pour footings and put a support beam mid span.
Ron
B. Franklin 1759
Old 07-02-2011, 09:05 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Yeah...max on a 2x10 is 15'10". IMHO that length span would be way too bouncy and I dont think you'd be happy with the result.
Do as Ron suggests.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
thomasjmarino (07-02-2011)
Old 07-02-2011, 09:11 AM   #4
Rewards Points: 150
If done as Ron states it will cheaper to build because of the change in joist size.
josall is offline   Reply With Quote
Old 07-02-2011, 05:06 PM   #5
Registered User
Rewards Points: 4,924
Ron has the solution. Again....
Help on the other questions, ledger attachment, footing size, etc.: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Some species only span 13'+, read the chart included.
Gary
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
