Debris Possibly Fell On Fireplace Insert - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 10:01 PM   #1
Debris possibly fell on fireplace insert
I was drilling some 1 1/2 inch holes through the top of the chimney frame in my attic to run some conduit. There was a lot of shavings from the drill that fell into the cavity, and at first I was terrified that they had fallen all the way down to the top of the wood burning fireplace insert. I realized shortly thereafter that there is a floor/ceiling between the two floors inside the cavity.
But I'm still a little worried that something could have fallen down onto it. How would a round metal chimney typically pass through that floor/ceiling? Would there be collar (might not be the right word) like there is in the attic - the square metal piece that surrounds the chimney and sits on the frame? Is it possible that anything fell all the way down to the box? Is it a fire hazzard if something did?
jakerbug is offline   Reply With Quote
Old 01-24-2010, 05:28 AM   #2
Rewards Points: 582
This photo may help, although these are UK codes.
stuart45 is offline   Reply With Quote
Removing a pre-fab fireplace insert MarkinTN1 Remodeling 1 10-10-2009 12:20 AM
Monessen Gas Fireplace Insert fisherro HVAC 3 12-25-2008 06:37 PM
Fireplace Insert mcblackburn@nc.rr.com General DIY Discussions 6 11-19-2008 10:33 AM
Ventilation for fireplace insert dpreznik HVAC 3 07-28-2008 07:59 PM
Gas Insert is too small for fireplace! manOfConstantSorrow HVAC 1 02-23-2006 07:07 PM
