Dealing With Damp - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 12:43 PM   #1
Dealing with damp
I would really appreciate some opinions/advice on the following.
I live in an upside down house,bedrooms down stairs,as the house is built on a gentle slope. The house is currently being renovated and at the moment has no rainwater goods etc. On friday we had heavy sustained rain and on saturday when I went into a bedroom that is only slightly below ground level at one point(only bedroom below ground level and only room that was affected with dampness), I noticed that the floor looked quite wet. I lifted the floor tiles some were very wet underneath. Prior to the refurb we lived in the house and the room in question was actually our bedroom. We never noticed any damp, the carpet was not rotten etc.
A couple of questions,
As there are no gutters etc to take the water to drains at the moment would it be possible that the water would have seeped through the soil and found its way down to the bedroom. If this was the case it would suggest to me that the damp proof membrane which is possibly 40 years old has broken down.
I am planning on digging down the side of the house to see how far down an external memebrane goes. I was also thinking of painting the room, walls and floor with a liquid DPM, has anyone used these and of so are they any good? Would this just push the water somewhere else, ie up the walls
Any thoughts/comments very gratefully received
Mumof2 is offline   Reply With Quote
Old 06-27-2011, 02:06 PM   #2
Rewards Points: 5,336
Take some exterior photos of the area outside the effected room. Some shots of the roof line would help.
Did you do anthing to the exterior that might have caused the water influx?
Does the water drain off the roof over this area?
What's the grading like?
Ron
B. Franklin 1759
Old 06-28-2011, 12:31 PM   #3
Rewards Points: 582
June's been a really wet month and the lack of gutters won't help matters.
stuart45 is offline   Reply With Quote
Old 06-28-2011, 05:56 PM   #4
Rewards Points: 4,726
no building code requires basement walls to be waterproofed to my knowledge,,, this means it can take years before any leaking water is noticed,,, water runs down hill & usually its path is easier thru non-compacted backfill.
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Damp walls lara1234 Building & Construction 6 10-28-2009 03:10 AM
Damp walls - should I use foil bubble wrap!? thenap80 Building & Construction 7 12-18-2008 11:40 PM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 07:00 PM
