#1 |
Deadbolt and Wood Trim question
Im trying to install deadbolts on my front doors but just realized the products I bought will not work as I have wood trim around my doors. It sticks out to about 1/2 to 3/4 of an inches making the products I bought unusable because the deadbolt wont latch. I was wondering if there any other products I should buy or if there any suggestions. Thanks
#2 |
Apprentice
Mark where the dead bolt will go through the trim; mark it out with a pencil; take trim piece's off after you have the pencil marks, use a utility knife to cut right under those lines, try making it perfect. Then get a real sharp chizel and the lines you made with the utility knife start to chizel right into them slowly. I say use utility knife to make lines under the pencil lines because once you chizel the trim out, it wont fit but take sand paper to make the cut a little bigger so the dead bolt piece can fit.
Thats what I would do. I know you don't want to ruin the trim because one little knick stickes out like a sore thumb. Thats my idea.
>>SooN<< |
#3 | |
Deadbolt and Wood Trim questionQuote:
Ron |
#4 | |
#5 |
I have thick pine molding around all my doors, it is in addition to door frame i guess. The doors shut inside the pine trim/molding which sorrounds the door.
#6 | |
Old School
Do you mean your doors have had a frame added to their faces for decoration, making them too thick for the depth of the deadbolt to work with the frame nailed on there?
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#7 |
Deadbolt and Wood Trim question |
#8 |
Willie, nice job with the interpretation!
Just take a hole saw, one size up from the outside dimension of the deadbole and cut just through the trim. Install the deadbolt as usual. Another possible option is to contact the manufacturer to see if they have parts to modify the lock so you can use it without the door modification. Basically longer screws and the tabs that connect the two cylinders.(or the cylinder and the latch. Ron |
#9 |
Old School
This is how the bigger hole (the one that will just clear the diameter of the deadbolt cover) will look.
Inside this hole, you will drill a smaller hole, one the size that the paperwork that came with your deadbolt calls for. All the big outside hole is for is just to be able to get down to the surface of the original door face with a neat hole that will accomodate the fat keyhole part. I drew this trim MUCH fatter than it really is so you could get the idea.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 05-18-2009 at 07:20 PM. |
| Display Modes | |
| Fixing a wood door... | CuCullin | Carpentry | 6 | 10-27-2007 07:46 PM |
| Deadbolt suddenly won't retract | Squeeealer | Carpentry | 1 | 07-14-2005 09:20 PM |
