Deadbolt Hole In Metal Door/frame - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 02:27 AM   #1
Rewards Points: 1,062
Question
deadbolt hole in metal door/frame
i have a metal fire door on my shed and would like to put a deadbolt lock for extra security (live in a city). but i don't think i have seen metal cutting hole saw blades with 14-18 TPI, all i've see are wood ones. any ideas?
thanks
Old 07-18-2011, 05:01 AM   #2
DIY staff
Rewards Points: 7,174
All the Milwaukee and Lenox blades at the big box stores are metal cutters.
amakarevic (07-18-2011)
Old 07-18-2011, 07:29 AM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
You'll probably need to drill a 2-1/8" hole. You can get some like this for under $16. ( just make sure you get a pilot bit if it's not included)
If the drill you plan to use for this project has a side handle on it, USE IT! When these saws contact the metal they tend to bite hard. Using a drill equipt with a side handle will help prevent marring up your door ( and breaking your wrist!!)
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Old 07-18-2011, 11:41 AM   #4
Originally Posted by Mr Chips View Post
...and breaking your wrist!!
i know what you mean. i had a couple of close calls like that but never did break it. looks like it would hurt...
The Following User Says Thank You to amakarevic For This Useful Post:
oh'mike (07-19-2011)
Tags
deadbolt , metal drill bit
Need a remedy for Hole drilled too big in Granite ginnieny Plumbing 6 11-10-2010 09:27 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
