Dead Bolt - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 01:18 PM   #1
Question
Dead bolt
I am tiying to fix a loose dead bolt, no visable screws, one key on outside, thumb lever on inside. I cannot get thum lever off to trveal screw.
I did use a paperclip and pushed on the pin and nothing.
cherri is offline   Reply With Quote
Old 01-22-2011, 01:26 PM   #2
I had a lock like that on my door. I found out I had to turn the cover on the lock on the inside to remove the case and reveal the screws. If I remember right it was a Kwikset. I remember I had to use channel locks and a rubber pad to keep from messing up the finish. Got all my tips from my local hardware store...
2dcook is offline   Reply With Quote
The Following User Says Thank You to 2dcook For This Useful Post:
cherri (01-22-2011)
Old 01-22-2011, 04:10 PM   #3
Rewards Points: 5,336
How it gets taken apart will depend on the manufacturer. Some locks require removing the escutcheon plate. Some have allen screws holding the knob on.
The manufacturers' name should be on the latch. Look it up on the internet and look for the installation instructions.
Or post a picture here of the lock and someone will direct you.
Ron
Old 01-22-2011, 10:42 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
look on the bottom of the thumb lever, there may be a set screw that needs to be removed
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Tags
deadbolt , door
Existing dead bolt cross bore 2 1/2" in wood door? boneglove Building & Construction 1 11-08-2010 08:44 PM
Problems with dead bolt in new door jkrodger Remodeling 12 01-12-2009 11:14 AM
My dead bolt is broken kimigriffith General DIY Discussions 3 06-09-2008 01:02 AM
double cylinder dead bolt sleuth General DIY Discussions 1 04-06-2006 07:46 PM
