DC Above Grade Egress Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 01:27 PM   #1
DC above grade egress window
what are the requirements - size, height above floor, square footage, etc, ??
mkl0726 is offline   Reply With Quote
Old 01-20-2011, 02:44 PM   #2
Rewards Points: 6,652
Only your local code enforcement office (ie City office that issues building permits) would be able to tell you what their codes are regarding Egress windows in your part of the country. Usually if they have a website with the info available, you may want to check that to see.
Old 01-21-2011, 12:54 PM   #3
Registered User
Rewards Points: 5,514
As Greg said; check locally.
Here is the number for IRC R310.1.1, notice the at-grade exception; http://publicecodes.citation.com/ico...9_3_sec010.htm
Gary
Egress window, structurally safe? jdm001 Building & Construction 15 01-20-2011 06:38 PM
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 12:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
