Old 10-25-2009, 04:48 PM   #1
lara1234
Default Damp walls
Hello,
I am buying an old Victorian house and the Surveyor mentioned that it had some dampness in the solid brick walls and advised getting another survey from a damp control specialist.
The specialist said that it was rising damp due to the damp course being old and would require chemical injection, and all the walls replastering.
Does this sound right?
Thank you.
lara1234 is offline   Reply With Quote
Old 10-26-2009, 07:47 AM   #2
If you live where all the rain has come this summer, everything is damp, or waterlogged. But if the gutter/downspout system is not working right, getting water away from the foundation. Fixing that could solve the problem. And there were never any considerations giving for damp conditions in those old foundations. Sounds like snake oil salesman to me.
Old 10-26-2009, 08:39 AM   #3
expect a ' damp control specialist ' what's we call ' waterproofing ' 'cepts its really not - we just ' manage ' it,,, i'd think bentonite ' rather'n ' chemical grouting ' but that may just because we're separated by a common language place a 2.0 x 2.0 alum foil patch on the wall AND floor,,, ck it 24hrs later - if the wtr's under, its vapor from whichever surface.
just how much has it been raining in old foggy town, anyway ? ? ?
itsreallyconc is offline   Reply With Quote
Old 10-26-2009, 12:03 PM   #4
ccarlisle's Avatar
Rising damp can also be treated chemically (often with silicones) or physically by putting a waterproof membrane along the perimeter of the damps walls about 6" above ground level. IMO, the best is the membrane although probably more expensive. I would ask around for quotations on both methods...
Is this a relatively new problem? If so, it may be serious but if it's in a Victorian home one can only wonder how long it's been like that. Is it moving? And if there's plaster over it, there's no point in replastering unless the damp has been controlled.
ccarlisle is offline   Reply With Quote
Old 10-27-2009, 06:27 AM   #5
Surveyors doing an HSV will often find a few damp patches on old houses and recommend another survey by a specialist to cover themselves.
The 'specialist' is often a salesman with a damp meter and nothing else. By getting a few readings above your skirting boards they usually say something like 'sign the contract for a chemical damp course and re-plaster with sand/cement and added salt retarder today and get a good discount'.
A friend of mine is a damp surveyor for the Building Research Establishment, and often does independent surveys including second opinions. He takes a van load of equipment out with him. He told me that 90% of rising damp cases were actually caused by either penetrating damp or condensation. Of the true rising damp cases very few were a failed DPC. Most were something else like the ground levels being too high, or leaking pipes in the screed.
If you need a meter to find the damp spots, and there is no mould or damage to decorations and dampness in the skirting boards the I wouldn't spend thousands on work not required.
BTW damp meters used by most surveyors are really designed to measure the moisture content of timber, not masonry.
stuart45 is offline   Reply With Quote
Old 10-27-2009, 08:13 AM   #6
ccarlisle's Avatar
Ah, well then, if the 'specialist' wasn't, then there the whole issue of ethics/qualifications etc that enter into the picture...get more qualified quotes in that case and investigate the investigator.
Old 10-28-2009, 05:10 AM   #7
lara1234
Thanks to everyone that posted, all the comments have been really helpfull.
More On This Topic
Hi, I am Danielle DeCamp with Intuition Salon and Spa. I am the footcare specialist here. So after we finished the entire pedicure you want to make sure that you clean your entire area. Now what you really want to do is make sure you throw away all the... Read More »
EMF stands for "Electromagnetic Field," and some believe that EMF readings are useful in identifying the presence of ghosts. Low level and moving electromagnetic fields are said to occur at locations that are experiencing paranormal activity. Evidence of... Read More »
Hi! I'm Mark Sullivan for Expert Village and today we will show you how to build a privacy fence around your yard. The first step in building your fence is to check all zoning requirements, any height restrictions, any set back requirements on your... Read More »
Part 1 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Learn how to clean a fender stratocaster electric guitar in this diy guitar tech video. Read More »
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 10:17 AM
Staining Interior Basement Concrete Walls techinstructor Painting 0 03-15-2009 04:15 PM
Damp walls - should I use foil bubble wrap!? thenap80 Building & Construction 7 12-19-2008 01:40 AM
Rising Damp and Old Stone Houses Hells_Belle Building & Construction 0 05-05-2008 06:07 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 04:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
