Damp Concrete Floor In Shop - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 02:55 PM   #16
Rewards Points: 462
Thanks for the explanation. I'm not so much worried about discoloration of the floor as I am about the tools rusting, although the damp sawdust on the floor is annoying when it gets into your shoe treads and gets tracked all over everything else.
Geez, and when they built the shop they asked me if I wanted a floor drain in there. Now I could use one for the dehumidifier but instead gotta run a hose into the garage....damn
Richo is offline   Reply With Quote
Old 04-11-2011, 03:45 PM   #17
Rewards Points: 5,336
How long ago was the slab poured?
How long does it take to "give up it's water". I thought concrete fully cured in and a month, give or take.
Ron
Old 04-11-2011, 03:51 PM   #18
Concrete & Masonry
Rewards Points: 576
Is this always damp, or just this weekend with the extremely humid weather?
My shop floor was sweating for the first time that I've ever noticed yesterday. It's a heated floor with 2" of insulation & vapor barrier under it, and never sweats otherwise. But, the warm humid air yesterday, coupled with the cold concrete, certainly created a damp floor.
My 35 year old garage floor on the other hand, w/o a VB, literally had water running down it to the drain.
How warm are you keeping the shop in winter usually?
jomama45 is online now   Reply With Quote
Old 04-11-2011, 03:56 PM   #19
Rewards Points: 462
I'm guessing the slab was poured in early July. It didn't even sweat like that during the most humid days last summer.
Yesterday was extremely humid and yes, the garage floor was soaked. I guess my big mistake was opening the windows in the shop without realizing how humid it was outside. The let it all in and made it much worse.
The shop isn't always damp but I did first notice some moisture on the floor about a month ago when it was getting in the 40's outside, hardly a spring thaw at that point. I normally heat it to 55 or so, but only when I'm using it, otherwise the heater is completely off.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 11:50 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
