Damp Concrete Basement Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 03:13 PM   #1
Damp concrete basement walls
How do I eliminate or seal concrete basement wall from the inside?
Dennis Grant is offline   Reply With Quote
Old 07-12-2011, 05:35 PM   #2
Rewards Points: 5,336
I'd get a dehumidifier.
Ron
B. Franklin 1759
Old 07-13-2011, 03:38 AM   #3
Rewards Points: 4,806
1st, let's discuss ' eliminate ' basement wall from the inside - are you really sure you want to do this ? ? ? if so, run a sawzall along the sill plate to free the house then jack up the house & diamond saw the walls loose from the footer if attached,,, can't imagine why you would want to do this but its your house
2nd, why do you think your bsmt walls need sealing - this assumes you're now leaving them in place.
Old 07-13-2011, 07:02 AM   #4
pls, do NOT give out advice unless you know what you're talking about as it degrades the forum's credibility,,, appreciate your effort to be helpful but nothing you posted works ,,, generally speaking, one either MANAGES leaking water from the inside OR STOPS IT from the outside,,, concrete sealer won't do dick nor will ANY paint - even drylock
The Following 3 Users Say Thank You to stadry For This Useful Post:
AGWhitehouse (07-13-2011), coderguy (07-13-2011), jomama45 (07-13-2011)
Old 07-13-2011, 07:05 AM   #5
Originally Posted by Patiosclotures View Post
The basement wall where the water was entering was repaired from the inside of the house actual leaks must be stopped either by sealing them inside with a concrete. Always use regular concrete sealer or an oil based paint.
Can you edit this post so it's readable?
How do you know what the OP did?
Ron
B. Franklin 1759
Old 07-13-2011, 09:01 AM   #6
Rewards Points: 640
you can't stop water coming in from the inside, you will have to dig up the ground around where its at outside and look for cracks in the foundation, or places where it is not sealed. fix the crack if there is any, and reseal the foundation from the outside... if you put drylock on the inside or paint it to hide it with latex you will just be storing the water in the foundation as it has no real place to go
BlueBSH is offline   Reply With Quote
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 03:49 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
