Damp Basement Wall. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2007, 12:16 AM   #1
damp basement wall.
Hello to all.
We live in Chicago burbs. Every winter during heavy snow after the snow melts we observe a mild dampness in one corner of the basement walls. We moved into the house 2 years ago. It appears that the previous owner had sealed/patched some water/moisture seepages in the same corner area as our home inspector had observed the patching.
Now after a snow storm we again observed water/dampness in the same place. It is a very small area but (20 inch by 2 inch) i am wondering what I can do to completely eliminate this problem. I am attaching a pic of the basement wall. One can see that the wall was patched before to avoid water seepage and it seems to be working fine. However one area of the patch is now again moist/wet. The wet patch is just on the corner edge as I have indicated in the image (labeled MOIST DAMP AREA ).
What shall I do. Any advice will be deeply appreciated.
itguru is offline   Reply With Quote
Old 12-16-2007, 12:44 AM   #2
What sort of problem is this causing? I think I'd probably just ignore it. It doesn't appear to even be enough to prevent you from storing stuff on the floor in that corner.
NateHanson is offline   Reply With Quote
Old 12-16-2007, 12:52 AM   #3
Thats what we have been doing since we moved into the house. We just ignored it and it dries off on its own. I am just wondering that by ignoring it, I hope it wont become something major..
Can this area be permanently sealed so this moisture wont come in at all.
Old 12-16-2007, 01:49 AM   #4
My understanding is that sealing a basement from the inside is not very effective, because the moisture is under pressure from the outside, so you can't put a coating on the inside that will hold it back.
If there are cracks or seams in the concrete there, then you might cut down on the moisture by sealing them.
I don't think there's any reason to expect it to get any worse though.
Old 12-16-2007, 02:46 AM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
you need to see why it`s happening there,whether from exterior grading ,or a roofing/siding problem traveling down the bearing wall,I wouldn`t leave it alone,especially w/all the mold and health issues,you may not have mold on the cement,but I would want to be sure to eliminate it from the path of the leakage
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 12-16-2007, 12:12 PM   #6
itguru,
Is there a downspout gutter entering the ground at that location?
Is there a roof structure change close to that location?
Is there a foundation close to the area such as a garage without a basement set back from that area?
Is ther a porch foundation near that area?
That water is originating from above and needs to be stopped otherwise over time it will cause corrosive damage to the reinforcing of the concrete walls.
Please respond
Pete A.
Professiona Building Designer
OVE
panthony is offline   Reply With Quote
Old 12-16-2007, 04:23 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,............
Once you fix the Issue allowing the water to gather there in the 1st place,........
Then you can Water-Block it on the Inside..................
It could be as simple as a Low spot in the grade of the lawn..........
Old 12-16-2007, 06:02 PM   #8
so-elitecrete
Rewards Points: 150
this is normal,,,
as most basements are engineered & built to leak,,, no one likes it but that's what happens w/o the proper exterior steps when installing the footers & walls,,, just be happy you've got conc instead of block,,, & no, there's no interior method that'll permanently resolve this issue, either,,, but follow the suggestions from the responders who advis'd ' look outside ' for the solution.
IF the water's coming in thru a crack or void, you can have the ' hole ' inject'd w/hydrophyllic polyurethanes,,, not a diy project, tho, as you only get 1 chance to d-i-RIGHT ! ! !
might want to also educate your home inspector.
so-elitecrete is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 05:29 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
