Damaged Sill Plate/ Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 01:39 PM   #1
I have an 8 foot section of my sill plate in the crawl space that has completely rotted away. The rim joist over this span has started to rot, and is deteriorating. This happened many years ago, and the house has already settled into its new place. The floor joists are now resting on the foundation.
I found the source of this problem (a concrete pad underneath the deck), and had it removed.
My question is, since I have removed the source of the problem, and the house has already settled, can I just leave the damaged sill plate/ rim joist? Or is the house in danger of collapsing because the rim joist is mostly deteriorated?
The sill was only 1/2" thick, so there isn't really anything noticeable since it settled (there is a slight dip in the hardwood floor above).
bignateyk is offline   Reply With Quote
Old 04-28-2010, 01:49 PM   #2
Try driving in waxed 1/2" thk 2 by wood pieces with the leading edge beveled. Their length is your sill plate width. Use a wood block between the wedge and your maul to prevent splitting the wedges.
Old 04-28-2010, 01:54 PM   #3
ok, that would take care of the sill plate. What about the rim joist? Is having a damaged rim joist ok as long as the source of the damage is taken care of?
Old 04-28-2010, 05:54 PM   #4
kwikfishron's Avatar
Rewards Points: 576
Wax wood will not fix your problem but a few pictures from the inside and out would be a good start.
One story house or three?
kwikfishron is online now   Reply With Quote
Old 04-28-2010, 08:09 PM   #5
If it serves the same purpose as bridging, wouldn't additional bridging close to the joists fix this?
How much Joist sitting on Sill plate? scott j Building & Construction 8 02-03-2010 10:00 AM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 02:07 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Termite Damaged Sill Plate cary00silve General DIY Discussions 17 01-07-2009 01:52 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
