Cutting A Truss For Supply Run? - Building & Construction - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-02-2008, 10:01 PM   #1
shuship's Avatar
Cutting a truss for supply run?
Can you cut one leg from a V in a rafter then reinforce with vertical studs to allow for a supply run?
shuship is offline
Old 12-02-2008, 10:07 PM   #2
That's not engineered wood is it? You need a structural engineer to determine that.
hvaclover is offline
Old 12-02-2008, 10:12 PM   #3
shuship's Avatar
Can I cut a truss for supply run?
I would like to cut one leg from a 'V' of a rafter in my basement to reroute a supply vent. Can I do this without compromising the integrity of the structure?
see pic please....
shuship is offline
Old 12-02-2008, 10:15 PM   #4
shuship's Avatar
Yes, it is engineered wood. Has anyone come across this issue?
shuship is offline
Old 12-02-2008, 10:24 PM   #5
You're talking to him. You cannot cut engineered wood with out compromising
it's integrity. You'll weaken that entire section...may even cause it to break loose and cave in. The truss is designed as a single unit. Cut it any where and and it'll weaken and come down like a house of cards.
You should bring this up in the carpentry or building and construction forum....I'll be watching .
Old 12-02-2008, 10:33 PM   #6
whew! that was getting uncomfortable for awhile. Glad you broke the tension nice job
burr is offline
Old 12-02-2008, 10:34 PM   #7
shuship's Avatar
you're welcome...
shuship is offline
Old 12-02-2008, 10:55 PM   #8
He's on the WATCH list, burr
Old 12-02-2008, 11:49 PM   #9
An old Tradesmen
Rewards Points: 7,332
The trusses are designed to spread the weight across the trusse, not just in a downward direction.
If you scab it, it won't spread the weight, and you will have a trusse failure.
The failure will cause damage to the walls of the room its supporting. And to anything, or anyone under it at the time.
If you alter your trusse/trusses like that. When your failure occurs. You insurance will probably NOT cover the damage.
Since its not caused by accident, or normal fatigue.
beenthere is online now
Old 12-03-2008, 12:00 AM   #10
shuship's Avatar
Do you have any ideas of how I may go about rerouting the lines without having to build a soffit? Plans are to install a drop, but would like to keep as much headroom as possible. Thanks again for your help.
shuship is offline
Old 12-03-2008, 12:09 AM   #11
An old Tradesmen
How much of a drop.
Old 12-03-2008, 01:26 AM   #12
shuship's Avatar
beenthere - sorry for the delay. no more than 4" if thats possible.
Can you look at this pic and see where the truss was engineered with the cutouts I have in mind of doing?
shuship is offline
Old 12-03-2008, 03:41 AM   #13
Whatamess
If you are only cutting one you would be fine.
I may go home hungry, but not tired and hungry.
TazinCR is offline
Old 12-03-2008, 03:46 AM   #14
An old Tradesmen
Key phrase is, Engineered.
That trusse has an engineers stamp of aproval to support X amount of weight at X amount of deflection.
And not snap, crap or pop.
Once altered, you change how it will disperese weight.
You'd be supprised at all the bull there is just to cut a 6" round hole in a dang I=joist.
Old 12-03-2008, 03:52 AM   #15
shuship's Avatar
Tazin - I plan to only cut one leg per truss, but in order to complete the run, I need to cut a series of 5 on one side of the preexisting trunk supply line and three on the other. Feasible? I've posted pics of what I'm trying to complete.
shuship is offline
Closed Thread
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
Roof truss sprung wireliner Carpentry 3 01-08-2007 10:10 AM
