Cutting Tip Plate For Main Stack - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 04:55 PM   #1
Rewards Points: 270
cutting tip plate for main stack
not sure if this is a plumbing question and belongs over there - more to do with roughing in
I want to push a 3" stack up inside an interior wall and out thru the roof. I have a 4" hole saw to cut thru the top plate (thinking this will accomodate the 3 - 1/2 " o/s diameter of the abs pipe) with a bit of wiggle room. But this will only leave @ 3/4" of top plate on either side of the opening. I'm almost slicing right thru the top plate by the time i'm done
This is not a load bearing wall - but is this acceptable?
thanks
rtoni is offline   Reply With Quote
Old 03-06-2009, 05:48 PM   #2
Remodeling Contractor
you should be cutting an oval hole. The top plate should be strengthened with metal straps and a metal notch plate.
Old 03-09-2009, 03:21 PM   #3
Rewards Points: 270
thanks for the reply - I've seen metal straps all over the big box stores, but nothing like a metal notch plate - assuming this would fit around the pipe on top of the original top plate?
Old 03-09-2009, 03:52 PM   #4
no something around the pipe would be called a flange. A notch plate is used so errant nails do not penetrate something that you installed through a hole in the studs. The steel strap is to restore the structural integrity of the wood you cut.
Old 03-09-2009, 04:34 PM   #5
Rewards Points: 270
gotcha - thanks again for the replies
Cutting into top plate. Clutchcargo Building & Construction 1 11-02-2010 06:59 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
