Old 09-07-2009, 09:09 PM   #1
Cutting tile on a diagonal
How do you cut tile diagonally in a straight line? I have a small wet saw.
kntry is offline   Reply With Quote
Old 09-07-2009, 10:43 PM   #2
nap
You talking to me?
nap's Avatar
1. mark the tile and follow the line
2. make a jig that would hold the tile 45º rotated
Old 09-08-2009, 08:36 PM   #3
yummy mummy's Avatar
You can measure from one corner and then measure the other corner and make a line, and cut, cut, cut......
yummy mummy is offline   Reply With Quote
Old 09-08-2009, 09:05 PM   #4
I can't cut a straight line without a guide. I can't draw a straight line either. LOL I CAN paint a straight line, if that makes any sense.
I've been searching and found something here called a Boomerangle. I'm going to try to find one tomorrow.
Old 09-09-2009, 12:52 PM   #5
Forget the wet saw......
How about you score your tile with a scoring tool, then cut a coat hanger, tape it to a table, and place your tile on so that the rod of the coat hanger is directly below the line of where you want the tile to break.
Apply pressure and voila, the tile is snaped......
Use a ruler to draw a straight line.......
Old 09-09-2009, 12:57 PM   #6
I'll try that. It might work. I've called around trying to find the boomerangle locally but no one knows what I'm talking about.
Thanks!
Oh, I have to use a ruler to draw a straight line.
Old 09-09-2009, 05:44 PM   #7
If you are cutting on a 45* angle just use a speed square against the fence and the tile.
NJ Brickie is offline   Reply With Quote
Old 09-09-2009, 11:52 PM   #8
Try this link; http://www.johnbridge.com/vbulletin/...ad.php?t=28371
Mop in Hand is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Laying diagonal tile on first floor - unsure of how to meet up the tile HRS1 Flooring 9 08-22-2009 04:50 PM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 01:33 AM
Cutting Tile rookie1 Remodeling 9 10-22-2007 05:25 PM
