Cutting Through Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 02:16 PM   #1
cutting through rim joist
I want to replace a wall-mount kitchen faucet with a deck-mount faucet, and am trying to determine where the plumbing is within the wall, if it is accessible from under the sink. I cut through the wall under the sink, only to find that there is a 2x10 or 2x12 board inside the wall, and the pipes appear to be on the other side of this board (between it and the exterior brick). I don't know the terminology, is this a rim joist, sill plate, or something else? Can I cut through it to access the pipes? There is wall cavity on both sides of this board. The house is single level, on slab foundation. Thanks for any help.
sm99 is offline   Reply With Quote
Old 11-24-2008, 03:03 PM   #2
knewbie
curapa's Avatar
Is the 2x running between the studs or under them? If it is between the studs then it's not structural and its probably there to hold the water lines in place. A pic would be helpful.
Considering it's a single 2x I assume its not structural in any circumstance but theres no telling without veiwing its connections and such.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 11-24-2008, 03:26 PM   #3
Thanks for your reply. The board runs between the studs. Since it's on a slab foundation, I can't imagine that it's load-bearing, but I don't know what restrictions there might be on cutting through it.
Old 11-24-2008, 03:54 PM   #4
knewbie
curapa's Avatar
I would imagine it is just blocking, depending on its location in the wall it could be there for several different reasons, cabinet nailer, hold water lines or maybe its an exterior wall and its holding the faucet line for outside.
Old 11-24-2008, 05:17 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
i would have to agree with curapa. Being your on a slab there should not be any rim joist. which makes me believe it was put there to hold the pipes. BOB
Cutting into rim joist dkwyler Carpentry 7 10-16-2008 10:43 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 10:56 PM
sister a joist Jack Hass Carpentry 7 06-19-2007 06:39 PM
