Cutting Through Baseboard? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 03:56 AM   #1
Rewards Points: 552
Cutting through baseboard?
Is there a tool I can use to make a neat, vertical cut through baseboard molding? I've attached some images of some trim work I'd like to do using cedar 1 x 4's and 1 x 6's. Note the bottom right section of the first photo showing where the vertical cedar board connects with the baseboard. Thanks.
Cutting through baseboard?-img_3056.jpg   Cutting through baseboard?-img_3055.jpg   Cutting through baseboard?-img_3057.jpg
kcrossley2 is offline   Reply With Quote
Old 09-13-2007, 04:44 AM   #2
Tool
The Fein Multi-tasker would work here. Its a bit pricey, but has lots of attachments, one I liked was one to clean out grout that needed to be replaced. German made and is a smooth running . Good luck! I saw it on late night info-mericials and that was the best price too after other internet searches.
roger1 is offline   Reply With Quote
Old 09-13-2007, 05:25 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Fein MultiMaster
Link: http://www.fein.de/fein-multimaster/...ons/index.html
- Build Well -
Old 09-13-2007, 05:48 AM   #4
Rewards Points: 552
Man, that's cool. Which model would you purchase? http://www.amazon.com/s/ref=nb_ss_gw...0&Go.y=0&Go=Go Also, which blades should I get for the baseboard cutting?
Old 09-13-2007, 04:01 PM   #5
Rewards Points: 552
This is a really cool tool, but is there another tool I can rent at my local home depot that might do the same thing?
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Tile Baseboard leted_82 Flooring 3 07-07-2007 11:57 AM
Cutting exiting baseboard flush with tile mowedthelawn Carpentry 21 06-24-2007 11:53 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 07:52 AM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 06:16 AM
