Cutting Subfloor Of Basement Landing To Get 12ft Sheets Of Drywall Down - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 08:56 PM   #1
Cutting Subfloor of basement landing to get 12ft sheets of drywall down
suppose your basement landing is contructed as below. I have about 3 feet of height from the middle landing to the basement ceiling. I need another foot or so to pass the 12 foot drywall through. Would it be damaging to cut out some of the subfloor from this landing? How would you fix the cut out subfloor?
Cutting Subfloor of basement landing to get 12ft sheets of drywall down-photo.jpg
casnj is offline   Reply With Quote
Old 03-30-2012, 09:08 PM   #2
DIY staff
Rewards Points: 7,174
Go for it---I've done worse---removed all the treads from a staircase one time to bring in a cabinet.
To rebuild the landing--sister in a 2x4 onto the joists and replace the subfloor that you removed.
kj6887 (03-31-2012)
Old 03-31-2012, 08:13 AM   #3
Are there no windows you could take out to get the sheets in? We have vinyl windows, and I just unscrewed them...brought in my sheets, resealed and rescrewed.
lowvolter is offline   Reply With Quote
Old 03-31-2012, 08:25 AM   #4
unfortunately the windows in the basement are those short ones
Old 03-31-2012, 08:29 AM   #5
Rewards Points: 512
i personally would just use 10ft or 8ft sheets and have a couple extra butts to skim out, watch you'll get that 12fter down the stairs go to put it up and SNAP! you now have 2 6fters and a nasty butt joint to mud!
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
DangerMouse (03-31-2012)
Old 03-31-2012, 09:11 AM   #6
it appears to me (although I could be wrong) that length is not the issue...it's the 4' width that is creating this dillemma
Old 04-02-2012, 07:19 PM   #7
its a combination of both getting them to the basement
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 11:30 AM
Basement stairway landing require footing? Clutchcargo Building & Construction 5 09-26-2011 09:31 PM
Hanging Drywall in Basement slamseven Building & Construction 3 02-26-2011 02:27 PM
Drywall basement Tcs Drywall & Plaster 2 11-26-2010 10:16 AM
Cutting drywall for electrical outlets. Mark Harvey Building & Construction 2 03-24-2010 08:31 PM
