Cutting Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 11:09 PM   #1
Cutting Stucco
Anyone have any way to cut a clean 4 inch hole thru stucco ? I know i could use a 1/4 inch bit and drill fifty holes around the edge but i was thinking maybe 4inch diamond grit hole saw ? any thoughts ?
MWHITLEY is offline   Reply With Quote
Old 02-25-2008, 11:54 PM   #2
A round hole is a bit more involved but I use my Roto-Zip with the right angle attachment and a masonry wheel to cut razor straight lines in stucco for doggie doors. Perhaps a similar cut-out tool (Roto-Zip, DeWalt) with a masonry bit and circle cutter may work nicely. Or freehand may work too.
End Grain is offline   Reply With Quote
Old 02-26-2008, 08:57 AM   #3
so-elitecrete
Rewards Points: 150
you can also buy,,,
a regular hole saw to fit your electric drill,,, much less expensive,,, stucco's not all that thick.
so-elitecrete is offline   Reply With Quote
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
Stucco leak (long post) Pat B. General DIY Discussions 1 03-24-2006 06:54 PM
