Old 02-20-2009, 04:50 PM   #1
cutting stringers!!!!
after much cursing and gnashing of teeth, somehow got three long stringers all roughly the same, to within a shim and a dab of glue here and there.
anyway, the book i go by says to "split the line" with the skill saw.
i find it impossible to use the first stringer as a template. somehow to cut always gets messed up bigtime.
after scribing the template onto the second piece, it's like, "now do i split the line again, or do i need to be on the far side of it, and LEAVE the line?
anyway, this never works, whichever way i do it. i have to go back with skillsaw/jigsaw, and try to clean up lines, and then i just butcher it.
isn't there a way to cut three 2X stringers at the same time, precisely? this crap drives me nuts.
i have a small mountain of destroyed stringers...
by the way, is Spruce OK to use for stringers? that's what i have now. i find them much cleaner and straighter than fir, although i just had a piece of a stringer snap off sideways on me with the spruce. not sure...
wombosi is offline   Reply With Quote
Old 02-20-2009, 04:56 PM   #2
RippySkippy's Avatar
When ever I make a template from the "master", I always cut the line out. BTW use a sharp pencil....
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-20-2009, 05:05 PM   #3
Remodeling Contractor
you leave the line and saw on the inside edge of it. The line was drawn outside of the template. So why would you cut this line, which means you cut beyond the line. And if the line is cut, are you past it and how much. If you undercut the line you can belt sand to the line and again you are perfect.
Old 02-20-2009, 06:04 PM   #4
Old School
Willie T's Avatar
I can't recall seeing anything but SYPKD called out for stairs around here.
Willie T
Old 02-20-2009, 06:10 PM   #5
Old School
Willie T's Avatar
BTW, schmolze, are you lifting the guard up out of the way when you try to start those stringer cuts on an angle? Almost impossible to get a clean cut on a stair stringer if you don't. I prefer to lift the guard and lower the blade into the side of the line.
Willie T
Old 02-20-2009, 06:11 PM   #6
Xtreme DIY'r
Stairs in the house or outside?
I cut so the blade goes on the edge of the line
Old 02-20-2009, 06:34 PM   #7
I think spruce is not okay for any structural member.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Outdoor stairs: notched vs housed stringers? shtoink Building & Construction 10 02-03-2009 08:21 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
