Old 08-22-2006, 02:52 PM   #1
MLO
Cutting rebar?
Will a large set of bolt-cutters cut #4 and #5 rebar easily?
Have a remodel foundation to do and would rather buy a tool than rent for nearly the same dough.
MLO is offline   Reply With Quote
Old 08-22-2006, 11:32 PM   #2
Cutting rebar?
A good set of bolt cutters, 36" or larger will cut up to #5 rebar, but cheap ones won't last long, and "easy" is a realtive term.
Tscarborough is offline   Reply With Quote
Old 08-24-2006, 12:30 AM   #3
Cutting rebar?
Buy a diamond blade for your circular saw for about $15US.
It will cut through rebar like butter and save you a ton of money in bolt cutter purchases or rentals in the mean time...
manhattan42 is offline   Reply With Quote
Old 08-24-2006, 03:00 AM   #4
MLO
Cutting rebar?
Thanks for the heads up!
Old 08-24-2006, 08:09 AM   #5
General Contractor
joasis's Avatar
Cutting rebar?
We use a standard cut off saw with an abrasive blade for cutting rebar. Same will work in a skil saw.
joasis is offline   Reply With Quote
Old 08-24-2006, 10:53 AM   #6
renovations
Cutting rebar?
"Buy a diamond blade for your circular saw"
Diamond blade for masonry or stone, but steel? I've always used abrasives.
Bonus is offline   Reply With Quote
Old 08-24-2006, 07:54 PM   #7
robertcdf's Avatar
Cutting rebar?
I cut rebar in concrete all the time when cutting holes. I also use my angle grinder with a diamond blade too. It works great.
robertcdf is offline   Reply With Quote
Old 08-24-2006, 10:26 PM   #8
renovations
Cutting rebar?
Well, you learn something everyday, huh? I'll have to check that out, tks.
Old 08-25-2006, 11:21 PM   #9
Cutting rebar?
Diamonds will cut rebar 10X times faster than abrasive metal cutting blades at many times less the wear...
A single diamond blade can do the work of 5 abrasive blades in half the time.
No brainer.
Diamond blade on a circular saw.
Diamond is cheaper and faster.
Old 08-26-2006, 04:09 AM   #10
General Contractor
joasis's Avatar
Cutting rebar?
We use abrasives because we typically cut 5 to 15 bars, #3 or #4's at a time...takes all of 5 seconds in a 14 inch chop saw...if someone gets a heavy hand and blows a blade, $3 for the fix. We also have a dedicated rebar cutter bender that we rarely use.
Just another example of do what works for you.
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
cutting glass victor General Discussion 2 08-07-2007 12:51 AM
Rebar in Electrical Conduit!! DIYDaddy? Building & Construction 5 07-06-2007 11:54 PM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 06:39 PM
Kitchen sink/counter cutting help? Lambo Carpentry 4 06-17-2006 05:50 AM
