Cutting Paver Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 02:21 AM   #1
cutting paver stone
Hey guys i am going to be making a small patio with paver stone.
its my first time and i want to make curved borders so will need to cutt the paver bricks
i went to the local tool rental, and a wet saw with diamond blade is going to run me 90 bucks for 4 hours, which is nutts
i was wondering, do i have any alternatives?
Can i get a blade for my 12" mitre saw and use that? do paver stones have to be cut wet?
i have seen the brick breakers but seems they just dont give nice clean cuts...
any suggestion will be much appreciated.
thanks
hi09 is offline   Reply With Quote
Old 04-25-2010, 02:42 AM   #2
you could use a mason blade on the chop saw, another thought is a tile table saw. you can get something worth taking home just over 100 bucks and it allows you to freehand the shape cut you want. also will be useful in the future since we all seem to have projects come up over the years
http://www.homedepot.com/Featured-Pr...atalogId=10053
is one idea, the little 4" guys for $70 will work on brick but you'll probably burn it out after a day or two of work. the motors in the little guys really struggle with bricks
racebum is offline   Reply With Quote
Old 04-25-2010, 07:24 AM   #3
Rewards Points: 4,534
that's because there's no 'grain' to brick, genius trying to achieve pro results using amateur tools tells me all i need to know,,, quit being a cheapskate - get the right tools & do it right OR hire it out,,, if you don't, the satisfaction of saving $$$ will be erased permanently by having to look at shoddy results in yrs to come.
its YOUR home, fergawdsake,,, unless you've got a bus in the front yard w/18wheeler tires for planters, don't you want the place to look good
ps - when our demo saw's busy & we need another, we pay about that rate, too - full day's $125 INCLUDING blade wear & we cut dry !
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
stone paver edging - what do you think so far? 31b Project Showcase 1 06-01-2009 12:08 AM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 07:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
