Cutting Patio Stones - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 12:20 PM   #1
Cutting patio stones
Hi all,
I'm trying to cut patio stones (the kind that is mostly formed concrete) to fit a walkway. I have so far used a chisel and hammer to to cut the stones. I am successful when I cut the stones straight, but I've had no luck cutting along a diagonal line- the stone crumbles into odd shapes or cracks in the wrong spot.
I am wondering how to cut these along the diagonal. I don't have many to cut, so a time consuming method is preferred over expensive.
Do I just need to sharpen my chisel and be very careful?
RR
Red Robin is offline   Reply With Quote
Old 07-28-2011, 12:26 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
try an angle grider with a diamond blade. probably ceaper than breaking a bunch of your stones.
mustangmike3789 is offline   Reply With Quote
Old 07-28-2011, 07:13 PM   #3
Concrete & Masonry
Rewards Points: 568
An angle grinder will certainly work well, but if you're having fairly good luck chiseling already, I'd look for a short piece of steel angle iron (like 3" x 3" x 1/4" or larger) to chisel over. Just line the cut directly over the 90* corner of the angle iron & hit directly over the top with your hammer & chisel.
jomama45 is offline   Reply With Quote
Old 07-28-2011, 07:38 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
From the backside drill a series of holes along any line you wish, drill about 80% through the stone. THEN use your chisel.
You can also use 16-20 penny nails to drive into the holes with a mallet, first one then another then another then back to the first ones again until the stone fractures.
When the stone finally fractures you won't see the holes from the top side.
You can do the same thing with the angle grinder and diamond blade idea. Cut a deep slot then drive nails into the cut.
XXX
Old 07-28-2011, 09:28 PM   #5
Civil Engineer
Rewards Points: 4,772
I had a number of cuts I needed to make in concrete block. The block was about 2 inches thick. I purchased an inexpensive (under $20) diamond tipped blade at a big box store, and used my circular saw to make the cuts. Works great. Just be sure to use adequate amount of water to keep the blade cool while you cut, and wear a good face mask (concrete dust is toxic).
Old 07-29-2011, 09:21 AM   #6
Thank you all.
Good suggestions here. I will give it another go this weekend.
Cheers
RR
Tags
chisel , patio stone , walkway
cutting out foundation wall for patio door lfunk11 Building & Construction 9 03-27-2011 09:55 PM
re: concrete patio stones gramps416 Landscaping & Lawn Care 3 02-23-2011 09:25 PM
what kind of pattern with these stones for patio? fabian Landscaping & Lawn Care 1 09-03-2010 07:55 AM
laying small stones in mortar on a patio Gary Schenk Building & Construction 1 09-21-2009 09:27 AM
Cutting a Concrete Patio steve65 General DIY Discussions 4 01-31-2007 06:30 PM
