Old 11-19-2008, 02:33 PM   #1
Power Gen/RS Engineer
Cutting Owens Corning Foamular 150
I am going to be using Owens Corning Foamular 150 ridgid foam insulating boards for an upcoming project. What is the best way to cut the boards to size? I plan in using the 2" thick boards.
Thanks!
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 11-19-2008, 02:40 PM   #2
concretemasonry's Avatar
For straight cuts, a good, sharp Stanley box cutter to score and snap or a hand saw.
If you have angles or openings, a hand saw works or a drywall saw works for small openings.
Sawing is messy, but you have a better chance to keep a good line if that is important.
Hot wire cutters can get to be a problem.
concretemasonry is offline   Reply With Quote
Old 11-19-2008, 04:08 PM   #3
RippySkippy's Avatar
I use a standard snap knife, with the blade fully extended. Couple the knife with a carbide knife sharpener when the snap blades get dull and you should be able to cut the foam easily.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Owens Corning Recall RooferJim Roofing 29 01-07-2010 10:18 PM
Owens Corning vs. GAF wojogirl Roofing 1 07-25-2007 12:44 AM
Owens Corning Shingles wojogirl Roofing 7 07-17-2007 03:30 PM
Is owens corning the only brand that does this? Malcolm Roofing 5 06-08-2007 09:46 AM
