-   -   Cutting Owens Corning Foamular 150 (http://www.diychatroom.com/f19/cutting-owens-corning-foamular-150-a-32200/)
BigJimmy 11-19-2008 02:33 PM
I am going to be using Owens Corning Foamular 150 ridgid foam insulating boards for an upcoming project. What is the best way to cut the boards to size? I plan in using the 2" thick boards.
Thanks!
Jimmy
concretemasonry 11-19-2008 02:40 PM
For straight cuts, a good, sharp Stanley box cutter to score and snap or a hand saw.
If you have angles or openings, a hand saw works or a drywall saw works for small openings.
Sawing is messy, but you have a better chance to keep a good line if that is important.
Hot wire cutters can get to be a problem.
RippySkippy 11-19-2008 04:08 PM
I use a standard snap knife, with the blade fully extended. Couple the knife with a carbide knife sharpener when the snap blades get dull and you should be able to cut the foam easily.
