Cutting Out Some Top Plate In A Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 04:13 PM   #1
cutting out some top plate in a load bearing wall
Can i remove 2 stud spaces worth of a top plate in 2 different locations on a load bearing wall in my basement to allow for my cold air returns to come up? My wall is about 28' long with 2 openeings on each end for a 32" door
smanteufel is offline   Reply With Quote
Old 10-08-2011, 04:20 PM   #2
Framing Contractor
Rewards Points: 120
Pictures might help.
Otherwise......NO!
sixeightten is offline   Reply With Quote
Old 10-08-2011, 05:48 PM   #3
Gymschu's Avatar
Rewards Points: 942
There's not a scenario where I would ever think that would be a good idea.
Old 10-08-2011, 07:16 PM   #4
Too Old
Is this new construction?
Through the floor or to the attic?
2 stud bays will weaken the wall no matter how you try to patch it back, and you are talking 2 areas Why not put a chase in and then you will not have to cut any plates?
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
load bearing wall question mudpaws Carpentry 3 06-24-2011 09:39 PM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
