Old 09-27-2008, 06:14 PM   #1
Cutting off 3" of laminate counter top in place
I find I have a house with TOO small of frig opening and newer cabinets installed in the 70's The LAST 3" of cabinets UNDER countertop is a filler board. SO,,,,,, thought cutting that 3 inches off and using THAT filler board to move top cabinets over 3 inches toward window would give me a 36 " hole. (ALSO going to move uppers 'up' 2 inches for taller friges these days)
Asked at Menards and they never heard of an electric flush cut saw,,do they make those?? Okay I will defer to YOU 'experts',,,what is the best and most efficient tool to cut this laminate counter with back splash attached off in place?? Straightest?? Least chips?? MOST professional looking??? Something I can reach back corner with??
Which tool would cause LEAST chipping?? circle saw? jigsaw? sawsall? Other?
Any other tips I forgot?? Thanks in advance!!! -d-
4just1don is offline   Reply With Quote
Old 09-27-2008, 08:14 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
a small router riding along side a straight edge would be your best bet I feel but it could also be done with a jigsaw & circular saw buy clamping a piece of pine over the area your going to be cutting, install a wood guide on the pine and then align with your cut, this will prevent chipping but will need some finishing against the back splash. then cleaned up with a belt sander. Then best way is to remove the top and cut it with a circular saw from the bottom and then the back. BOB
Old 09-27-2008, 08:37 PM   #3
I agree with Buletbob. Use a straight edge. Clamp it to the front of the counter and apply double stick tape or hot glue under the rest. Use a carbide tipped scoring hand tool, available in tile department/store. Score the edge enough to cut into the dark substrate. Be sure to allow about 1/4" overhang to be sure not to expose cabinet below, as your cabinet might not be 90 degrees to the counter top.
Since you have scored the top you can use a jig/saber saw with a new wide blade and follow your line. When you get to the backsplash, hot glue a small piece of wood to the splash and repeat thecarbide cut up and over the top. Then use a reciprocating saw aka "sawzall" with a new wide blade and follow the line. No matter what you use, you'll need to clean up the edge with either a belt sander or a power sander with 80 grit paper. At this point you can file the edges and either glue another strip to the edge or paint it.
RemodelMan is offline   Reply With Quote
Old 09-27-2008, 10:33 PM   #4
I just did this very thing on a recent kitchen reno.
I have a fine toothed handsaw (approx. 16 teeth/inch) and sawed it by hand.
I placed masking tape where the cut was to be made and penciled a line on the tape to follow with the saw.
It may take some time, but with care, a neat job may be acheived.
More On This Topic
Learn How to Sharpen a Sawzall Blade in this free tool care series from our knife sharpening expert. Read More »
How to Use an Edge Sander
How to Use an Edge Sander by Expert Village
Okay, I'm going to show you how an edge sander works. Okay it's a rather large tool, it's a disk sander more or less the disk spins around on here, you can put a big heavy grit on it and then go down to a finer grit, but it has a plate that moves around... Read More »
Making your own sandpaper belts instead of going to the hardware store to buy them can be time-consuming and not particularly cost-effective. But as with anything, if you've got the time, you can certainly do it yourself! Once you get the hang of making... Read More »
Types of Reciprocating Saw
Types of Reciprocating Saw by Expert Village
Rod McMahon for Expert Village we are going to talk about the different types of sawzalls. There is a lot of them out there. This particular one is a Milwaukee super sawzall. It is a very powerful motor. There is a lot of them out there that are 4.5 amps... Read More »
We've already cut our paper for the bottom of the box, 11x11. Now what I'm going to do is switch out my blade. I want to take my cutting blade out and put my scoring blade back in because from now on, all we're going to be doing is scoring. The first... Read More »
Laminate Counter Tops, clear coat? joedreamliner787 Painting 2 09-01-2008 10:55 PM
attaching countertop analogmusicman General Discussion 22 08-10-2008 12:53 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
Repairing scratch in laminate counter Keyo77 General Discussion 2 02-03-2008 02:00 PM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 09:42 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
