Cutting Metal Barn Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 09:57 PM   #1
Rewards Points: 616
cutting metal barn siding
i was wondering what cross cuts "across the ribs " the best and a saw is out of the question for warranty purpose. and if it is electric shears what type the regular or the ones that leave the curly q's "like milwalkee"
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-02-2012, 12:19 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
What does a saw have to do with the warranty?
Don't all shears leave "curly-cues"?
titanoman is offline   Reply With Quote
Old 03-02-2012, 12:25 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
saw will throw chips embedding in the soft paint finish,most panel manufacturers don't allow sawing
the curly q [double cut] will usually have less distortion then the regular snips
best is a profiled guillotine
Tom Struble is offline   Reply With Quote
Old 03-02-2012, 09:39 AM   #4
Concrete & Masonry
Rewards Points: 470
This is what I use for both the cross-cut's and the "rips". It takes a little practice to get it through ribs on cross-cut's but it works OK. The best approach I've found is to order the steel pre-cut from the factory.
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
mae-ling (03-02-2012), Tom Struble (03-02-2012)
Old 03-02-2012, 03:55 PM   #5
Rewards Points: 2,202
I agree with Tom - I used to manage a lumber yard and we rented out our guillotine. On longer sheets it did pull a little so cuts were not straight, had to account for it and put it in at a slight angle. So you can use vice grips and clamp the sheet to the guillotine.
mae-ling is offline   Reply With Quote
Old 03-02-2012, 10:20 PM   #6
Rewards Points: 616
thank you for your info a guillotine is out due to cost vs how small job is also i do already have the milwalkee shears but i was told that they would not cross cut i have also heard of the malco brand tshd shears that do not leave curly q's that was next option i would love to use me milwalkee 8" metal circular saw but not an option
Old 03-02-2012, 11:16 PM   #7
rent a nibbler
http://www.cpotools.com/bosch-1529b-...bosch-nibblers
Old 03-03-2012, 12:05 AM   #8
Disabled wood vet
titanoman's Avatar
Even if you use one of those black fiber metal-cutting blades? They cut pretty clean if you don't go too fast except for a little discoloring.
I don't see why the manufacturor cares how you cut it.
Old 03-03-2012, 02:04 AM   #9
Rewards Points: 616
no they don't care if i void warranty so the do not have to pay for replacement of rusty panels
The Following User Says Thank You to jaydevries For This Useful Post:
mae-ling (03-03-2012)
Best tool for cutting metal nail plates Paul316 Building & Construction 4 08-28-2010 12:48 PM
cutting metal siding for pole barn South Branch Ca Building & Construction 2 09-22-2009 11:31 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
