Old 10-15-2006, 03:31 PM   #1
I can do it......I think!
Send a message via Yahoo to MovedTooMuch
Cutting Landscape Blocks - any advice?
I will be installing a small retaining wall. One side of the wall will be against the house so I will need to cut some of the blocks in half.
Lowe's does sell a masonary cutting blade for my recipicating saw BUT it takes forever to cut one block. Are there any tricks to this?
These are the medium sized blocks.
MovedTooMuch is offline   Reply With Quote
Old 10-15-2006, 03:46 PM   #2
OK. I did check Lowe's site.
http://www.lowes.com/lowes/lkn?actio...RetWall.html#3
"To accurately cut a block, score a line around it with a 3 1/2" brick chisel and a 3 lb. sledgehammer. Place the cutting edge of the chisel in the center of the score line and strike the chisel sharply with the sledgehammer."
Old 11-03-2006, 09:49 PM   #3
BTW, this did work pretty well. I did get the chisel with the protective guard. I also got a 4 lb. hammer rather than the 3 lb. since it actually cost less.
Old 12-20-2006, 05:00 PM   #4
Way to go Fred. I'm in the home stretch on my brick landscape wall and have cut quite a few bricks with the same method/tools you figured out. Trial and error will get you to the point where you look like a pro doing it.
GlenCoombe is offline   Reply With Quote
