Cutting Laminate Countertop From Lowes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 10:08 PM   #1
Rewards Points: 190
I had my new cabinets installed by a carpenter. He said he would prefer not to install he countertop and gave me places to call, he said I would be looking near $1,000 installed depending on what I want. I only have a 114inx114in cabinets so counter would be less.
I found the perfect laminate counter at lowes. The color is exactly what I was looking for. The sell it by 4 ft, 6 ft, 8 ft, 10 ft... The 10 ft may not need to be trimmed but the other piece would. How do I cut laminate counters without it chipping? How do I finish the ends then? Step by step procedure would be great. Thank you!
ryanb4614 is offline   Reply With Quote
Old 12-28-2011, 10:25 PM   #2
Rewards Points: 558
here you go, read up: http://www.ehow.com/how_7894258_way-...-chipping.html
epson is offline   Reply With Quote
Old 12-28-2011, 10:32 PM   #3
MarginallyQualified
Rewards Points: 2,464
He said he would prefer not to install the countertop...
there's a story in there
...said I would be looking near $1,000 installed depending on what I want.
For a proper full thickness laminate (wilsonart, formica, etc) on real plywood
glued up and installed (even if all done on site)... maybe that much.
If you're happy... then I'm happy.
But this isn't what I described above.
Here's a start:
Old 12-29-2011, 04:26 PM   #4
Rewards Points: 2,212
Some cabinet shops will cut for you. They can do 45degree cuts or whatever you needif your walls are not square.
Straight cuts can be done with a circular saw from the back side and a triple chip blade. i would not risk it for $100 around here I can get a shop to do the 6 cuts needed for a U shaped kitchen.
Some lumber yards sell matching end covers for the laminate counter tops.
mae-ling is offline   Reply With Quote
Formica Laminate Countertop How to? SimpleJack Carpentry 17 05-24-2012 11:02 PM
cutting a hole in a countertop rudyb22002 Carpentry 7 08-12-2011 05:16 PM
need to repair swollen particle board laminate countertop John DeKam General DIY Discussions 4 03-02-2009 06:01 AM
Laminate Countertop in Bathroom Least Expense? houston Kitchen & Bath Remodeling 2 02-01-2009 12:19 AM
cutting laminate with a saber saw? darsunt Flooring 6 02-22-2008 07:42 AM
