Cutting Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 08:11 PM   #1
cutting joist
I am installing a wood stove. I need to cut a floor joist. The joists are at 16 inch centers. If I designate the first joist as 0 the second one as 16 and the third as 32; the joists runs from a wall to a support header at 12 foot away. I need to cut a foot out of joist 16; this will be at 2 feet and 3 foot from the wall. That leaves joist 16 hanging at 9 foot from the support hanger. I want to header it between joist 0 and joist 32 with a 12 inch square box to hold my ceiling support box for the double chimney pipe. Will this work and exactly how will I do that?
Rfactor is offline   Reply With Quote
Old 04-20-2011, 08:20 PM   #2
Framing Contractor
Ask your building inspector because it has to be inspected anyway. He'll point you in the right direction.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-20-2011, 08:36 PM   #3
I guess that could be the answer to all projects and then we wouldn't need this forum. I guess I am saying that isn't an answer.
Old 04-21-2011, 06:49 AM   #4
DIY staff
Rewards Points: 7,174
Typically the uncut joists on either side of the one to be cut are doubled(sistered) then the joist is cut--double blocking is installed---and hangered---then the cut joist is hangered off or that.
Doubling the joists may not be needed,however,without seeing plans and load requirements--that is always a safe guess.
Rfactor (04-23-2011)
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Skylight Install - Cutting attic joist crossbeams? spup345 Building & Construction 1 08-26-2010 10:41 AM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Cutting floor joist for a flush mount girder lou94stang Building & Construction 2 12-14-2008 07:35 PM
Cutting into rim joist dkwyler Carpentry 7 10-16-2008 09:43 PM
