Cutting Iron Fence Sections - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 10:12 AM   #16
robertcdf's Avatar
Another tip is to use blue (or masking) tape around the area to be cut, this will give you something that you can easily mark and see your markings a lot easier.
robertcdf is offline   Reply With Quote
Old 07-08-2013, 07:13 PM   #17
The sawsall with new metal cutting blade is the way to go. Use a pair of vice grips set at your cut line as a guide. Works super
retiree is offline   Reply With Quote
Old 07-10-2013, 01:04 PM   #18
Originally Posted by md2lgyk View Post
I'd use an an angle grinder. There's absolutely no finesse with a Sawzall.
+1
Use a metal cut off wheel and you should be good to go.
jponto07 is offline   Reply With Quote
Old 07-14-2013, 09:38 PM   #19
robertcdf's Avatar
Originally Posted by jponto07 View Post
+1
Did you read at all? That powder coat will be ruined near the end if he uses a cut off wheel.
Old 07-14-2013, 09:43 PM   #20
Yes, I read it... Apparently you think a grinder would generate too much heat? I actually hadn't considered that factor.
Old 04-12-2014, 03:56 PM   #21
Doozer
Rewards Points: 123
Originally Posted by jagans View Post
... right angle grinder with a thin reinforced metal cut off blade. I have a Bosch 4.5 and I love it.
Have made a lot of cuts in Fortress railings with this exact setup. The 4.5" thin wheel is very cheap and that's good. They will cut fully through the 1" square steel tubing in one pass, but they do wear down quickly. Just be sure and hold it steady so it doesn't bind. There is ample room for slop inside of the standard brackets, but we have no trouble keeping it to within 1/8" of a tight fit on each end. Draw the line you want with a silver Sharpie and cut away the line with the grinder.
FatBear is offline   Reply With Quote
Old 04-12-2014, 04:38 PM   #22
Oso954's Avatar
Rewards Points: 1,298
9 months later, I would guess the cuts were already made.
Oso954 is online now   Reply With Quote
Old 04-12-2014, 09:18 PM   #23
Doozer
Rewards Points: 123
Ever hear of Google? Sometimes people use it to learn how to do things. I happened on to this subject while looking for something else and thought maybe I'd help someone else out.
Old 04-13-2014, 12:07 PM   #24
Rewards Points: 89
Actually I used my Dewalt 10 inch chopsaw with a metal blade.
Gave up on screwing the damn things into place and just Stick Welded them to the posts,and touched up with paint.
spring3100 is offline   Reply With Quote
The Following User Says Thank You to spring3100 For This Useful Post:
hand drive (04-14-2014)
Old 03-31-2015, 08:18 PM   #25
Knucklez's Avatar
Rewards Points: 932
Fatbar, i do that all the time too.
According to Medallion Fence, major supplier in my area, they recommend a metal cutting blade on a sawzal or jigsaw. i'm prepping for this type of project right now
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
weed wacking around a chain link fence reds_21 Landscaping & Lawn Care 23 07-30-2012 04:09 PM
Cutting Cast Iron J&N Plumbing 7 10-15-2011 08:45 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 07:04 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
