Cutting Iron Fence Sections - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 03:38 PM   #1
Rewards Points: 89
Cutting Iron fence sections
Picking up several panels of Fortress Fe26 railing for my deck project.
All of it comes in standard (6 and 8 foot) sizes and will need to be trimmed down.
Fairly substantial iron construction,with a nice powder coated finish,which I would very much like to preserve
What tool or tools are the best to get for cutting this.
Have a sawsall but dont think this will give precision cuts.
Sections won't fit on a chop saw
Don't want to burn pieces off with a torch
Hacksaw is for,you know,hacks
Does that leave my only choice a circular saw with a metal blade?
Makes me wish I was back in the Fire Department as a roof saw with a metal blade on it would make short work of the iron.
spring3100 is offline   Reply With Quote
Old 07-01-2013, 03:47 PM   #2
Rewards Points: 13,456
Why not order it cut to size?
No web site to look at?
Old 07-01-2013, 03:56 PM   #3
Rewards Points: 994
With a good variable speed sawsall and a Lennox blade, technique would need to be awful sloppy not to make precision cuts.
Old 07-01-2013, 04:13 PM   #4
Rewards Points: 3,130
I'd use an an angle grinder. There's absolutely no finesse with a Sawzall.
Old 07-01-2013, 04:38 PM   #5
Rewards Points: 994
I can't help your technique. You'll just have to learn that on your own. I have jeweler's shops waiting in line for my services.
Old 07-01-2013, 04:40 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
Ayuh,.... That'd be my 1st choice, with a thin disc....
Bondo is online now   Reply With Quote
Old 07-01-2013, 04:54 PM   #7
kwikfishron's Avatar
Rewards Points: 396
A metal cutting blade on the chop saw would be the only way to get a finish quality cut imo.
kwikfishron is offline   Reply With Quote
Old 07-01-2013, 06:17 PM   #8
Roofmaster
Rewards Points: 2,172
Milwaukee Porta-Band, or a right angle grinder with a thin reinforced metal cut off blade. I have a Bosch 4.5 and I love it. I can make good cuts with my sawsall too. The key is to use a fine tooth blade and keep the foot down on the work.
Old 07-01-2013, 06:40 PM   #9
Rewards Points: 396
The key would be the operator. Sawzall Art isn't for everybody.
Old 07-02-2013, 04:56 PM   #10
robertcdf's Avatar
We install a lot of that railing... GRINDER IS A NO GO! I'll say it again DON'T USE A GRINDER. Use a portable band saw, or a jigsaw with a metal cutting blade will do an OK job.
robertcdf is offline   Reply With Quote
Old 07-03-2013, 02:03 PM   #11
Bondo's Avatar
Ayuh,... Bein' an Iron Worker, I gotta ask,....
Why Not,..??
Old 07-03-2013, 02:42 PM   #12
Concrete & Masonry
Rewards Points: 548
Why Not,..??
It's powder coated metal.........
jomama45 is offline   Reply With Quote
Old 07-03-2013, 07:42 PM   #13
robertcdf's Avatar
Why Not,..??
Because it will bubble the powder coating on the end, it will take longer, it's not as precise (remember this is a DIY site these guys don't typically have a QUALITY grinder and a very steady hand)
Or just ignore the advice of someone who has installed over 100 of these panels and just wing it. Whatever. I don't care it's not on my house.
The Following User Says Thank You to robertcdf For This Useful Post:
hand drive (07-06-2013)
Old 07-06-2013, 09:10 AM   #14
AHH, SPANS!!!
Rewards Points: 1,166
just as Robert mentioned, do not add heat from the cut! it will melt the finish close to the cut. a good hardy metal blade on a sawz all or band saw will cut it with little heat involved. add tape or something similar to the base of the sawz all so you do not damage the finish with the metal saw base while cutting against the railing. maybe even clamp a guide next to the cut location to help keep the saw blade in place, a sawz all blade likes to bounce around...
hand drive is offline   Reply With Quote
Old 07-06-2013, 09:24 AM   #15
Davejss's Avatar
Rewards Points: 740
I'd use a hack saw with a brand new, fine tooth blade. Take your time and start your cuts with a few back strokes. Change out the blade as soon as needed. A bit slower than all the power tools mentioned, but not as slow as you may think.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
rustyjames (04-13-2014)
weed wacking around a chain link fence reds_21 Landscaping & Lawn Care 23 07-30-2012 04:09 PM
Cutting Cast Iron J&N Plumbing 7 10-15-2011 08:45 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 07:04 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
