Old 11-21-2010, 03:18 PM   #1
Cutting into wall to create a 24" tall by 15' wide crawlspace.
Hi again.
So, i think that I found a way to add more space to my office. So there is a closet in my office, I took out the doors and use is a shelving. I kinda like the way it is now.... but I need more storage space. See below:
[IMG]http://img408.imageshack.us/img408/7...paceonwall.jpg[/IMG]
[IMG]http://img831.imageshack.us/img831/5...lspaceplan.jpg[/IMG]
[IMG]http://img408.imageshack.us/img408/7769/depth.jpg[/IMG]
This seems a lot easier and faster than my other thread. I was wondering, can this work. I want to be able to support about 500-700 lbs. So, probably steal beams would be needed right?? Also, drywall, what is the best that should be used in this type of situation.
I want the "crawl space" to span the entire 15' wall, but should I have space between the "closet" and the "crawl space?"
Thnx!
Chesnut9 is offline   Reply With Quote
Old 11-21-2010, 04:52 PM   #2
Other then putting the door in the middle for easier access, this should work without a steel beam.
Ron
Old 11-21-2010, 06:11 PM   #3
So it would be able to hold half a ton without a steel beam! Ok great! Now, what about the beams supporting the house, how do I go about those???
Old 11-21-2010, 06:46 PM   #4
Call in a structural engineer to advise you based on an onsite inspection.
Ron
Old 11-21-2010, 07:08 PM   #5
k thnx man
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Cutting a wall? frankthetoad Painting 17 08-07-2007 12:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
