Cutting Into Top Plate. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 11:06 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Cutting into top plate.
I need to cut out the top plate of an exterior wall to install a beam (triple 11 7/8" LVL). This beam is used to open up a small sunroom (labeled dining area in the pic) for an open concept. I want to push the beam up as much as possible and that involves cutting out the original 4x6 top plate. Once I cut out the top plate, how do I tie the new beam to the top plate? Keep in mind that the original top plate is 3 1/2" wide and the beam is 5 1/4" wide.
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-02-2010, 06:59 AM   #2
Send a message via MSN to reality
Go to the simpson catalog they have everything you will need. You can Google this and download pdf files. There are plenty of retail stores that carry them.
reality is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 07:42 PM
