Cutting Hole Through Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 11:28 AM   #1
Cutting hole through joist
I am looking to add a 3rd zone to my HVAC system and heat my former attached garage which is now a living room. The easiest thing to do would be to cut a 2 1/4" x 12" hole through the end joist of my house from the basement which would allow me to install the vent. I would need to cut a second hole the same size for the return vent. The joist size is a 2x12. Does this sound like a bad idea or is it acceptable?
shaunz is offline   Reply With Quote
Old 10-20-2012, 11:48 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
shaunz,
here is a link to the code section in regards to notching of floor joists http://publicecodes.cyberregs.com/ic...9_5_par030.htm
and these are the diagrams from the code. I believe you're going to find that is over notching and could weaken your floor.
hope this helps
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-20-2012, 11:50 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
most of the time if cutting is needed on a structure it will need fortifying in some way or another to accommodate the cutting.
hand drive is offline   Reply With Quote
Old 10-20-2012, 11:51 AM   #4
GBrackins's Avatar
see reply from your post here (Threads merged)
Gary
Old 10-20-2012, 11:54 AM   #5
Thanks. And to add a little more detail. The joist I want to cut the two holes in is the one that sits on top of the sill plate on top of the concrete foundation wall.
Old 10-20-2012, 11:59 AM   #6
AHH, SPANS!!!
for all of my additions a hole is cut through the foundation and the ducting goes through the foundation wall... a big enough cut for both the return and main. The rim board may need to be doubled above the foundation hole
Old 10-20-2012, 12:33 PM   #7
kwikfishron's Avatar
Rewards Points: 86
If he's talking about cutting through a rim joist bearing on the foundation there should be no problem.
kwikfishron is offline   Reply With Quote
Old 10-20-2012, 12:52 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
+1 I agree
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-20-2012, 02:16 PM   #9
Rewards Points: 2,202
Originally Posted by BigJim View Post
+1 I agree
And I agree with his agreement.
mae-ling is offline   Reply With Quote
Old 10-20-2012, 02:59 PM   #10
Do you consider the 2x12 that goes all the way around the perimeter on top of the foundation wall to be a rim joist?
Old 10-20-2012, 03:09 PM   #11
Rewards Points: 86
Yes…some call it a rim joist others call it a band joist, it’s all the same.
The Following User Says Thank You to kwikfishron For This Useful Post:
BigJim (10-20-2012)
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
Cutting hole in concrete foundation wall Peter Carpenter Building & Construction 2 10-16-2010 01:21 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Skylight Install - Cutting attic joist crossbeams? spup345 Building & Construction 1 08-26-2010 11:41 AM
Cutting floor joist for a flush mount girder lou94stang Building & Construction 2 12-14-2008 08:35 PM
