#1 |
Cutting a hole in stone foundation
Hi,
I have an addition project going on, and basically what I have run into is I need to put a hole in the stone foundation wall between the addition and existing house. I have 2 questions: 1 - Can I cut a 5 inch round hole without comprimising structure? and if so 2 - Anyone have any recommendations on how to cut a hole in a stone foundation wall? Thanks |
#2 |
ICF Construction
A 5" hole will not compromise the structure provided you do not drill it in the angle area from a window or door (Where concrete habitually cracks).
Use a core hole bit for a rotary hammer drill, good chance you will have to rent since most DIY don't own $ 2k tools. You have two options, a handheld or one you mount to the wall and usually run water through it's much easier to work, but you need space to hang and operate, handheld is more compact but requires patience and skill.
Chris |
#3 |
Lic. Builder/GC/Remodeler
... Bring a chair ...
- Build Well - |
| Display Modes | |
| Floor Joists Lifting Off Foundation Walls?! | cbeingessner | Building & Construction | 2 | 06-12-2008 09:39 AM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
| Stone foundation for a small shack | andrgo | Building & Construction | 10 | 09-13-2007 02:49 PM |
| Finishing Over Natural Stone Foundation | mattgeiger | Remodeling | 2 | 09-09-2007 03:57 PM |
| Making an 8" hole in the brick | Hushpuppy | Building & Construction | 6 | 11-28-2006 08:17 AM |
