-   -   Cutting a hole in stone foundation (http://www.diychatroom.com/f19/cutting-hole-stone-foundation-15452/)
casualty x 01-10-2008 08:12 PM
Hi,
I have an addition project going on, and basically what I have run into is I need to put a hole in the stone foundation wall between the addition and existing house. I have 2 questions:
1 - Can I cut a 5 inch round hole without comprimising structure? and if so
2 - Anyone have any recommendations on how to cut a hole in a stone foundation wall?
Chris Johnson 01-11-2008 12:34 AM
A 5" hole will not compromise the structure provided you do not drill it in the angle area from a window or door (Where concrete habitually cracks).
Use a core hole bit for a rotary hammer drill, good chance you will have to rent since most DIY don't own $ 2k tools. You have two options, a handheld or one you mount to the wall and usually run water through it's much easier to work, but you need space to hang and operate, handheld is more compact but requires patience and skill.
AtlanticWBConst. 01-11-2008 06:28 AM
... Bring a chair ...
