Cutting Hole In Exterior Brick - Dog Door... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 09:09 PM   #1
Cutting hole in exterior brick - dog door...
I would like to cut an opening in our exterior brick wall of our house for a dog door.
Details:
- House: Single story brick in Texas / slab on grade.
- Plan on installing dog door on the back wall of the garage for access to a dog run.
- Exterior is brick / mortar, built in 1978.
I've never cut through an existing brick wall before but never having done something has never stopped me before... However, I am here asking first.
Can I get by reasonably well using an angle grinder to make the straight line cuts as needed through the brick?
Obviously I could rent a large gas powered 14" diamond hand held saw. These seems like it may be overkill and I'm thinking the smaller angle grinder would not have near the extended cut line of the saw kerf from the much larger gas powered unit.
I realize that the smaller angle grinder will be a bit slower but I have plenty of time.
Any suggestions on how best to proceed?
BTW - Mods, please move if this thread is in the wrong category.
Thanks,
Steve
CZSteve is offline   Reply With Quote
Old 03-08-2011, 09:28 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
How thick is the "brick" portion? Is it a solid 8" brick/block wall or is it a 4" (3 5/8" actual or less) with a wood stud backup? - That could change the type of equipment and saw blade that works for the opening the size that you need.
Dick
concretemasonry is online now   Reply With Quote
Old 03-08-2011, 09:42 PM   #3
It's 4" brick with wood stud behind it.
Old 03-09-2011, 05:24 AM   #4
Rewards Points: 4,584
since dick's still in bed, lemme try this 4"grinder & sawzall you can also use a circle saw & abrasive blade
New Door Thicker than Old Hole dsayles1 Remodeling 7 01-29-2011 10:50 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Help hanging a problematic door Termite Carpentry 12 07-21-2008 07:05 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
