Cutting Hole In Double 2 X 10 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 06:12 PM   #1
Cutting Hole in Double 2 x 10
I need to cut a 6" hole through back to back 2" x 10"s. What do you guys recommend to do this with? Are those RotoZip tools any good?
Build is offline   Reply With Quote
Old 06-19-2009, 06:24 PM   #2
What are the 2x10's supporting?
That is 6" out of 9.25"
If this is a header & support - I don't think you can
I think:
You can drill holes in joist no closer than 2 1/2 from the outside edge of the joist, but, the hole cannot be any larger than 1/3 the floor joist...3 1/3 inches
http://tileyourworld.com/constructio...oringGuide.pdf
Old 06-19-2009, 08:58 PM   #3
Registered User
Rewards Points: 526
So...... What did the installer say about the floor system resting on the flat 2x10, on blocks every 4'o.c., on a bearing beam?
Be sure the rims are supported, use a reciprocating saw, after you drill an access hole through both.
Be safe, G
Old 06-19-2009, 09:14 PM   #4
WOW, just saw the other thread
Who built that like that?
And why start another thread leaving out all the important info?
Old 06-20-2009, 06:13 AM   #5
You don't want to messing with single joists that way, let alone doubles. My pipe is only 2" OD and I won't even go dead center through 2x10s in double formation EVER, unless it is a double rim joist. Your floor joists are double for a reason.
There is a code for maximum penetration based on where you live and then there is common sense as well which is not so common in some tradespeople who unfortunately don't require a special license to buy a chainsaw or sawzall.
Generally speaking
if it's even a single 2x8 I won't even touch it with my 2 1/8 bits and if it's 2x10 I stay under the 1/3 maximum hole size guideline. I l drill 2 9/16 dead center and that's it. A good piping guy with some forethought will usually find a better way instead of the easy way, and furnace pipe can be manouvred into a lot of different offets.
Post more info on what you need here. It sounds like more of your ducting. If it is specific to your ducting you might also post the question about redesigning the ducting layout under HVAC but as Scuba says keep all the info together... and I don't think a rotozip would be what you're after on this one even if code allows it.
Chemist1961 is offline   Reply With Quote
Old 06-20-2009, 08:02 AM   #6
I guess I should have posted in my earlier thread then. The reason I did not was b/c the question about whether or not we can cut through the joist has been settled. The inspector came yesterday and said that it was no problem. He inspected the entire beam and said it was installed correctly and the joist we want to cut through is only there for transporting the house.
Please close this thread I will continue to post in the thread here - Cutting Board for Ductwork
Sorry for the confusion.
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
Cutting hole in basement wall bladesj Remodeling 4 06-14-2009 05:41 PM
buy a hole cutting for recessed lighting install? DIYGST Electrical 22 01-23-2009 02:24 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 06:28 AM
