Cutting a hole in concrete wall
You'll probably want to hire a contractor to do this with a core bit drill. It is like a hole saw, but diamond-tipped. There are contractors who specialize in just cutting- asphalt and concrete.
If you diy, you'll need to find a rental yard that specializes in industrial equipment and they will charge you for the wear on the core drill bit. For one hole, you'll probably be better off hiring someone.
Chris
