Cutting Hole In Concrete Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 10:10 AM   #1
Cutting hole in concrete foundation wall
When Cutting hole in concrete foundation wall is there a minimum distance from the house that needs to be excavated? I am planning to enlarge the window height and believe I can save money by digging myself and possibly installing the window well also. Peter
Peter Carpenter is offline   Reply With Quote
Old 10-16-2010, 11:42 AM   #2
Rewards Points: 5,336
It sounds like an egress window. Various companies sell kits for this application. What you need to install will depend on how high ground level is from where you step out of the window. Many kits have intergrated ladders or steps to get you up to the surface.
Ron
Old 10-16-2010, 12:21 PM   #3
Registered User
Rewards Points: 5,492
Yes, just search "angle of repose". Be very careful:http://jobsite.buildiq.com/articles/...on-safety.aspx
Basic egress info: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Gary
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Drilling Through Concrete Wall rjordan392 Building & Construction 8 07-23-2008 06:30 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
