Cutting Hole In 10" Joist - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 01:08 AM   #16
I am going to use one of those holes to go with. I think, if I use reducer and elbow it should work. Thank you very much, I appreciate it
Originally Posted by thekctermite View Post
WHOA! I read your post incorrectly and missed the part about the joists being light gauge steel. I hate those darn things!
We rarely see them around here so I don't have the boring allowances committed to memory but I'm thinking that you cannot do much more than you can do to wood to them, if anything at all. There is a manufacturers association for light gauge steel framing member manufacturers and I'm betting they have their prescriptive methods for cutting holes posted online. Can't think of their name off the top of my head unfortunately. The last time I inspected them in a home, the manufacturer did not allow any cutting of holes, as there was a fairly large rolled opening every three or four feet.
Bormanko is offline   Reply With Quote
Old 02-09-2011, 01:10 AM   #17
I will do it like that, Thank you very much for your help
Originally Posted by proremodel View Post
you don't have to off center anything grab a elbow or 2 of hardpipe or even flex pipe and bend it from the start point threw the hole you will be fine. Set the fan up were ya want.
Tags
cutting joist , duct work , reinforcing a joist
Joist cutting for recessed beam ojee001 Building & Construction 8 11-09-2010 08:06 PM
Cutting hole in concrete foundation wall Peter Carpenter Building & Construction 2 10-16-2010 01:21 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 03:02 PM
