Cutting Hardi; Shears Vs Hardi-blade?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 11:53 AM   #1
Rewards Points: 45
Cutting Hardi; shears vs hardi-blade??
Health benefits aside, how does the performance of the shears compare to a hardi blade on a chop-saw or circular saw? How difficult is it to make a straight cut?
kooshball is offline   Reply With Quote
Old 12-21-2009, 02:12 PM   #2
Next Time...New Build
Rewards Points: 150
THe sheers work really well. We always cut the board upside down since the stationary blades could leave an indentation on the finished side of the panel.
No dust and they easily chomp their way through with no problem. Very easy to maneuver when you are cutting out for a door/window as well. Use a chisel to clean out the corner.
I never used the chop saw for this but would think it would provide a little cleaner cut. However, the sheers provide a pretty clean cut....but the cut ends get caulked anyway.
RickyBobby is offline   Reply With Quote
cutting hardi board ponch37300 Flooring 22 05-13-2012 11:59 AM
Sharpening mower blade RDS Landscaping & Lawn Care 20 04-09-2012 09:49 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 08:08 PM
Blade for cutting engineered floor strips stallinc Flooring 3 06-20-2008 04:17 PM
