-   -   cutting a floor joist (http://www.diychatroom.com/f19/cutting-floor-joist-152716/)
henderjohn 08-05-2012 05:00 PM
I am installing a new walk-in shower, and the drain falls partially on a floor joist (2X10). I could remove a section of the joist to allow for the drain and trap, and sister a 2X10 in, or cut the section out and box the hole, running 2X10 s perpendicular to the cut joist to the adjacent joists. I'm wondering if both would be acceptable, but I'm leaning towards the boxing in. Code violation??
mae-ling 08-05-2012 05:56 PM
Would an offset shower drain work?
https://encrypted-tbn3.google.com/im...2HIB6tCNQ9ef2g
May need to slightly notch/shave top of floor joist.
Sister another one in beside if you have to notch existing.
GBrackins 08-05-2012 09:38 PM
if you take out one, install two before (one of each side of the opening with maximum of 16" on centers between them. Mae-ling's suggestion may be the way to go!
joecaption 08-05-2012 09:51 PM
The one in the picture looks more like a toilet offset.
http://www.amazon.com/SHOWER-DRAIN-O.../dp/B000K6GMGA
tony.g 08-06-2012 03:34 AM
Most Codes allow you to notch the joist, up to about 1/4 the depth,but only near the end of the joist (where the bending stress will be least).
For example, if your joists are 2x10 and you cut a short notch 2" deep near the end, you will be fine. If you cut a similar notch near the centre of the span, you will be converting it to a 2x8, and you will not be fine.
If you put pieces perpendicular to the joists, that will not add any meaningful strength to the notched joist.
mae-ling 08-06-2012 10:59 AM
I does, but it is for a shower.
