#1 |
Cutting a floor along a wall
I am tearing out my floorboards and replacing them with osb. I need to cut the floorboard where they meet the wall, up against the wall.
I can't get up close with a regular saw. I tried a Dremel but it barley cuts the wood and smokes really bad. Any idea how I can get up close against the wall? |
#2 |
Super Moderator
I usually use a SawsAll with a long blade -upside down in the machine---
Upside down allows you to make a shallow skim cut--Long blade will bend right up against the wall. Use quality blades--Milwaukee--Lenox---Sterret----Mike--- |
#3 |
Moderator
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 |
Military Mom of 4
Pashaw! Look at that sucker! I wish I had that when I redid the bathroom!
Ah - but, instead, I got as close as possible with my ripsaw and then just chiseled out the rest- it sucked - but it got done.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
#5 |
That's a neat tool....but will it cut all the way thru the floor?
Is the fixed depth deep enough? Rod |
#6 |
fabrk8r
Toe-kick saws are designed to cut 3/4" deep.
If you do get one be very careful using it. They are potentially the most dangerous tool you will ever use. If you will be cutting through any nails make sure the saw has a carbide tipped blade.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright |
#7 |
I bought one off eBay for $60! Thanks for the link, I didn't know such a tool existed.
| The Following User Says Thank You to tibberous For This Useful Post: | Snav (06-03-2010) |
#8 | |
Military Mom of 4
Cutting a floor along a wallQuote:
I want one! *eyes the fledgling savings account balance*
| Display Modes | |
| creating door in possible load bearing wall | acerunner | Building & Construction | 6 | 07-05-2010 05:33 PM |
| Cutting through masonry wall | mwpiper | Remodeling | 4 | 04-17-2010 11:30 AM |
| Breaking up a long/continuous wall | tigereye | Interior Decorating | 4 | 03-08-2009 04:43 PM |
| Temporary wall support question | discojv | Building & Construction | 7 | 01-25-2009 08:23 PM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
